| [ http://www.twinturbo.net/nissan/300zx/forums/technical/view/1045145/-Rehosted-images-.html ] I was reading the tech page above, but still had remaining questions. First of all, I could never find that blue connector near the fuse block at the driver side foot area. Is it behind the fuse block out of sight? Secondly, even if I find that, I'd have to add a wire out of the fuse box connection in the engine bay as described in the link. Can I just add a new wire from the ECU harness all the way to the fuel pump with a fuse on the newly added wire. Technically, I will be making a connection to a wire that already exists from the fuel pump to the fuse box in the car, but that leg of the wire doesn't go anywhere anyway. ECU----->Engine_Fuse---->Car_Fuse---->FPC |-----------new wire------>|
